Parts list
Posted by Mike CA on August 25, 2007 at 11:20:32 from (70.136.39.100):
Henry asked me to post this. If you have an old parts H, or just some of these parts laying around, please contact me. Thanks!
Parts I need to get the tractor running:
Oil pan with 4 bolts and split washers
2 way Sediment bowl (for duel fuel)
Hydraulic control arm
Hydraulic control mount
New Steering wheel
Choke rod
Seat pan bolt (hinges where pan flips)
Wing nut for carb
Engine block water drain plug
Parts I would like to get the tractor up to show quality.
These parts I need to get in order to use my H for a night hay ride at my son's school. So they are important to me.
Light bar
Lights
Rear light
Rear light mount
Amp box
Starter switch and mount
Battery box
Battery box support
Original radiator cap with single arm
Throttle arm linkage
Hydraulic pump rear access cover
(4) original side bolts for the grill
Small gas tank and associate fuel line
Lower radiator hose
Glass jar pre-cleaner
Air cleaner pipe
Narrow front with non-adjustable wheels
Grill insert
Junked Grill (to fix my ripped away piece)
Manifold Heat Shield and attaching hardware.
Mag On/off switch
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
