Posted by Janicholson on August 15, 2007 at 17:33:39 from (66.173.50.167):
In Reply to: old farmall governor posted by tom wiseman on August 15, 2007 at 14:02:14:
Tom, I'd wager you have an H or an M Farmall. If there is a tube running from the governor to the carb, front to back, that is probable. There are three things that can affect the tractor as described. One is a disconnected throttle linkage from the hand lever to the governor lever in back of the governor. Check this first. The hand lever should pull the governor lever all the way it can travel when wide open. Adjust it to do so. (springs and nuts on a threaded rod left side of engine) If this does not fix it, the next place to look is the prongs and tabs inside the tube leading to the carb from the governor. Two prongs on the shaft, and one on the carb throttle shaft. they must be interlocked, and are tricky to get correct. If it still has no throttle response it is probably inside the governor. Book needed!!! but doable in every way. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
