Posted by chadd on August 14, 2007 at 12:48:01 from (4.188.132.25):
Well, I replaced the intake manifold gaskets, the fuel filter, and the fuel shut-off solenoid. The two front plugs look darker now, so it appears that the front intake gasket was leaking some. However, the engine runs pretty much the same as before. I have done a compression check on it and found the following numbers: Cylinder 1: 149 psi Cylinder 2: 154 psi Cylinder 3: 149 psi Cylinder 4: 155 psi I don't know what the correct value is for compression on a C-153, but they seem decent, as all are within ten percent of each other. I also left the compression tester on each cylinder for about a minute, and none seemed to leak down in that time. I double checked the firing order and plug wiring and each seems correct, as the distributor rotates clockwise. What else could cause it to miss and sputter when revving it up and sound like it is not hitting on all four? Thanks.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
