Re: Farmall M slow hydraulics
Posted by the tractor vet on July 07, 2007 at 19:12:06 from (75.19.121.241):
In Reply to: Farmall M slow hydraulics posted by 80demoace on July 07, 2007 at 16:23:31:
More then likely it is the pump and also the old M's just did not have enough pressure even with the updater relief valve installed your only talken at best 1000 lbs if the pump is good . On the Jd. haybines the cylinders are SMALL as when they built them they were made for the newer tractors with higher hyd pressure and them littel cylinder wrok fine on high pressure . My buddy has a 1219 and that pice of GREEN junk is a thorn in my side . This year my buddy wanted to mow hay with the old JUNKY 720 John Deere and guess what it will hardly lift the 1219 . It will not lift the 7000 Deere planter as that was his other great idea to plant with it just not enough Hyd pressure on the older tractors . Not if you had a New Holland haybine with and external cylinder let say a 3x 8 it would lift it just fine but when they build the hyd . cyl. into the machine there is just no hope other then either get a newer tractor with more modren hyd. system and a higher working pressure of switch colors on the haybine .One other thing that ya could do is step up to adding a live hyd.'s to the M and then you could up there pressure to around 1250-1450 . But here you will have to upgrade the cam gear and camshaft as not to have the nut work loose on the cam and shear the key.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
