Oldiron29 about covered the mix/match I'd know of. The Regular, and I believe even pre-1929 15-30 would have the same butterfly and governor shaft mounting.
However, the 15-30 nearly for certain [2 carburator bolts for the waterbowl variant of the R, the RW], and probably different variations among 10-20 manifolds, same with the Regular, may not mount to your particualr manifold [likely 3bolt in the carb?].
If the cover was off the linkage and it sat outside you may have a rusty mess needing some soaking, else it really isn't that bad to take the linkage end off and pull the whole shaft out the carb side of the throttle tube [I know I use terms too interchangablely, the tube going from that to the governor is more of a "tube", while the one going to the carb better says "casting" to me].
A machinist should be able to get that idle screw drilled, and either removed with an extractor or retapped (though peeling the screw's threads away from the brass base is a likely a real bugger if the extractor doesn't take it), however, machine rates probably make a "new used" base cheaper unless you have a mill yourself.
The things [various components and complete carbs] do seem to pop up on ebay sporatically enough; else, I'd be rather surprised if Alderson or Fordson House [both can recieve a picture on email too, if you need to clarify the throttle mount] doesn't have a part reasonably priced, perhaps Rice Equipment even has an NOS base for that matter.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
