Re: Calling Janicholson
Posted by Janicholson on January 14, 2007 at 09:30:52 from (66.188.149.191):
In Reply to: Calling Janicholson posted by r4etired on January 13, 2007 at 17:54:03:
Yes. It is the best way. Here is my take on it. Jack up and block the rear end substantially supporting the axle housing on each side with blocking that can be trusted in all directions. Drain down the differential housing (it holds a lot of oil, be prepared). Remove the PTO in/out box and set it aside. Feel inside for the large bolts that attach in the center of the bull gear. Feel at the bottom of the housing where the bull gear teeth come near the casting feel the distance between the tip of tooth and the casting. locate a strip of hardwood that you can manipulate tand trim to fit into that space pretty well tight. Loosen the bolt and remove it. Mark with chalk a spot on the floor, and on the tire to help find the tire angular location for reassembly. Pull the axle out (a small jack between clamp and housing underneath might help with the weight of the tire on it). Do not move it out farther than the bull gear thickness to avoid loosing internal parts. As it clears the bull gear, stop. Now the gear can be moved back far enough to clear the flange on the pinion shaft. Remove the pinion shaft and carrier. Replace all components in reverse order. Some manipulation of the bull gear will be needed, but not as much as if it were to drop into the housing! I hope this is the content you need. JimN
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
