Re: Still no attempt to start
Posted by John T on January 02, 2007 at 19:08:50 from (66.244.90.5):
In Reply to: Still no attempt to start posted by ToddH on January 02, 2007 at 17:38:09:
Todd, All there is on that starter circuit is the battery n cables n starter switch n starter. Nowwwwwww it sounds like the cables n batery are alllllllllllll okay correct??? (If NOT check all of them n load test the battery and insure its good and its charged) Sooooo if the battery n all cables n grounds are good but no cranking that only leaves the switch n starter. Id isolate the switch or starter first by by pass jumping around the starter switch i.e use jumper cables from the hot ungrounded battery post direct down to the starter post or starter side of the switch n see what happens????? If she cranks then but NOT via the switch, its either a bad switch or a bad cable or connection on the switch. If she still dont crank even when you hot wire by pass with big jumpers direct to the starter, then it must be the starter. That allllll being said, the same problem can happen if theres even one single bad ground or cable or connection you know, sooooo Id remove, clean n wire brush, n reattach each n every battery n starter n ground n switch connection FIRST ALSO if the ground cable is on any thin or rusty sheet metal component, try reatatching it to a solid clean heavy frame bolt location, that may be the problem. FINALLY my guess is its the starter switch or else a bad cable or connection. In general if when you depress the starter switch the lights dim way down badly and/or the battery voltage drops drastically, THE SWITCH IS OKAY BUT THE STARTERS BAD However, if when you depress the starter switch the lights dont dim much and the batery voltage dont drop much, Id say the switch is bad. Hope this helps??? lemme know Ol John T and all in Indiana
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
