Re: super m valves
Posted by ChadS on November 19, 2006 at 11:55:52 from (66.228.96.130):
In Reply to: super m valves posted by makinhay on November 19, 2006 at 09:54:33:
Governor, or carb, or the gaskets leaking. Take the carb bowl off,,, set the throttle to the lowest postion, reach up inside the carb, and try to move the butterfly,, if it moves without resistance, you dont have the tang lined up on the throttle shaft, or the tang itself is worn and the slack will cause it to do that. The butterfly, at idle postion should be held shut by the governor, (when the engine is off) any free movement, check the linkage,,,, make sure the vertical linkage inside the governor is in adjustment, if its out, it will idle when you first start it, but as soon as the governor activates, it wont go all the way back to idle, so, you make the adjustment, with the throttle in idle, and you adjust the rod until the butterfly is held shut tightly. Other possibles, can be a vacuum leak, but it would be more erratic running than idleing high,,,,, Hope this helps a little. ChadS
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
