Re: 350 utility hydraulic problem
Posted by Unreserved dick on November 11, 2006 at 00:51:10 from (4.228.126.232):
In Reply to: 350 utility hydraulic problem posted by Ed Hir on November 10, 2006 at 14:34:27:
Since your loader worked OK on another 350U, it probably should on this one, too. We will assume it has double-acting hydraulic cylinders at this point, until you tell us differently. Given this, the most likely cause of the fill/dump problem that you are describing is having the control valve set for a single-acting cylinder. At the front of the control valve there is what the Operators Manual describes as a pin (turned with a 9/16" wrench) that has to be set to "D" for proper operation of your loader. Having the engine bog down the hydraulic system when its valves are centered is usually caused by a clogged orifice in the pressure control/safety valve block (the rear, inboard valve block, with no handle, assuming your 350U's hydraulics are as they came from IH). The cure is to remove the block and clean the orifice. The most common root cause of this is a dirty hydraulic system; you might be money ahead to pull the reservoir and clean the screen (underneath the cover), etc., while you're at it. If you do this, be sure to lift the cover straight up, and have a place to set it figured out; the screen is easily damaged and expensive. Best to get someone strong to help with this job if you can. Good luck, and let us know how you make out.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
