Re: voltage drain?
Posted by Janicholson on October 18, 2006 at 16:39:05 from (66.173.50.27):
In Reply to: voltage drain? posted by Russ Lowry on October 18, 2006 at 16:03:51:
The problem can be found with minor trouble shooting. First charge the battery with the pos post disconnected from the tractor cable. Leave it disconnected. Next use a portable/handheld volt meter to check the drain as follows: 1- Place the red lead from the volt meter on the positive post of the battery (use a locking pliers, or small C clamp, to keep it on there, being careful to not ground the pliers/clamp. 2- Place the black lead on the cable clamp that usually goes on the positive terminal but was disconnected above. 3- Look at the reading, if there is a major drain on the battery it will read 12 or more volts, maybe 12.6. If there is no major drain, it will read less than one volt. If it reads 12+ volts, begin by disconnecting one wire at a time, then checking the volt reading and reconnecting the wire if it is still at 12+ volts Use this order of disconnect. Alternator big wire from alternator. If volts drop, it is probably bad diodes in the alt. Alt other wires one at a time. If these it may need an internal voltage regulator. Light switch power lead from fuse/amp meter. If this is it, the switch is wired incorrectly or bad. Big Wire from starter switch to starter. If this is it the switch may be bad leaking current when off. Smaller (about #10)wire from start switch to amp gauge. If this is the problem, the wire, or amp meter may have a short to ground. Good luck, John T has a trouble shooting guide on this site in the archives. some of it is for gen systems and other parts for alt systems, good luck, JimN Finally wire from
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
