Re: C charging problems
Posted by John T on October 16, 2006 at 13:37:20 from (66.244.90.5):
In Reply to: C charging problems posted by Tim Mattson on October 16, 2006 at 12:10:19:
Tim, it sounds like you done went n did and/or Jim suggested most things I might have recommended, this makes it harder on us guys lol For one thing, some of the old 3 brush Delco gennys that used cutout relays n light switch field current control only put out something like 10 amps max on their best days. One thing I believe would help, although Ive never tried it on those, would be to go inside the genny n completely remove the 3rd adjustable brush and rewire the first lead field winding (one that 3rd brush was wired to) up there to the incoming ARM post just like the 2 brush gennys are wired. That should eliminate at least a part of the normal voltage drop which moving the 3rd adjustable brush was all about........ Other then that, and AFTER you insure a tight belt and BOTH the genny n VR are well grounded and the genny n VR are wired correct, do like Jim mentioned to dead ground the gennys field post n see if she charges better then??????? If so I suspect a poor VR ground or the VR is bad or misadjusted........if its no better leave it dead grounded and jump by pass the VR's Cutout Relay by momentarily wiring its BAT and GEN terminals together in case the relay has some carbon resistance. Once the field is dead grounded and the relay is jumped around the VR is basically out of the equation and any poor charging must then be a genny problem if not a miswiring or a bad ground or connection somewhere. You sure the battery is good??????? Had it load tested ??? A weak battery may not take a good charge you know!!!!!! If the gennys brushes are bad or the commutator is all gummed over it can charge but be weak also. My complete long winded troubleshooting procedure is posted probably 100 times below regarding charging problems but I dont think it would help much for you, check the VR and genny wiring and belt n grounds n connections AND ESPECIALLY FOR A BAD BATTERY and run the VR by pass checks and if thats alllllllll okay take a look at the gennys brushes n commutator and then maybe consider rewiring it as i suggested above as a 2 brush genny BUT LET US ALL KNOW WHAT HAPPENS John T
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
