Re: H Electrical...whats Up?
Posted by Bob M on October 05, 2006 at 06:32:48 from (151.190.254.108):
In Reply to: H Electrical...whats Up? posted by sstractoranch on October 04, 2006 at 19:49:23:
Tom - A voltage reading of 5.40 volts says the battery is being discharged. And the ammeter pegging on the charge side at the same time says either the ammeter is wired up backward **or** the battery hot and ground cable connections are reversed. --- Here’s what I’d do: 1 - Double check the battery ground polarity: The ground cable should be on the battery POSITIVE post. 2 - Check for proper ammeter function: Turn on the ignition or lights without starting the engine. If the ammeter indicates discharge you are good. But if it indicates charge, swap the wires at the two ammeter posts. 3 - Make sure the regulator base is solidly grounded. If it’s at all questionable run a separate ground wire from the regulator base to a good ground - like where the grounded battery cable bolts to the frame. 4 - Repolarize the generator. (With the battery connected and the ignition off momentarily jumper the regulator BAT and GEN terminals.) --- Now start and run the engine. If the battery **still** does not charge the most likely problem is a bad regulator. Hope this helps!
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
