Posted by JMOR on April 11, 2009 at 11:04:43 from (72.181.158.237):
In Reply to: Coil Question posted by mkirsch on April 11, 2009 at 09:14:33:
DUNNDAN said: (quoted from post at 12:56:41 04/11/09) I see what you are saying. The coil I have is a Niehoff. On the sticker it says "12V No external resister required" What do you mean when you say the distributor shorted out? The post on the side of the dist. has the wire from the + side of the coil attached on the putside. On the inside of the dist. the post has the following: a nut, then the condenser wire, then the points spring, then another nut that holds everything together. Should the condenser wire be isolated from the points spring? The points open and close fine. Gap is .021. They are new. The tractor ran fine last time I used it. Thanks for the help.
" What do you mean when you say the distributor shorted out? The post on the side of the dist. has the wire from the + side of the coil attached on the putside. On the inside of the dist. the post has the following: a nut, then the condenser wire, then the points spring, then another nut that holds everything together."
One place a short occurs is that the insulator on that post as it passes thru distr wall fails.
"Should the condenser wire be isolated from the points spring? "
No, the post, condenser wire & points spring are all common electrically.
The light bulb routine mentioned earlier is a good & easy test.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
