Re: Farmall A rings
Posted by Janicholson on September 23, 2006 at 13:33:18 from (66.173.50.77):
In Reply to: Farmall A rings posted by tyler cohrs on September 23, 2006 at 13:03:46:
Us made piston rings are all going to be reliable and appropriate. The issue may be cylinder wall wear. almost every worn set of rings also has worn the cylinder wall just as much. The very top of the cylinder will not be worn because the rings do not go to the top of the cylinder, they stop maybe 3/8" down in the bore. The resulting ridge (between the unworn top and the most worn area just below it are the indicators of the need to resleeve the engine. This ridge also makes removing the pistons difficult (without accidently removing the sleeves at the same time. (this engine has sleeves that have "O"rings on the bottom, and seal at the head gasket on the top. They are exposed to the water in the block on their exterior surface for cooling. If there is more than .004" difference between the unworn area, and the worn zone (measured correctly with a bore micrometer, or telescopic gauges) on the diameter, it will be best to replace the sleeves, pistons, rod inserts, and rings. Either way it can be measured without taking off more than the head to access the bores. Ridge reaming and honing the cylinders will be necessary if you decide to keep the old cylinders. If they are not ridge reamed, the new rings will smack against the ridge and break parts while making terrible noise. By the time you do all this reaming, honing and fitting, you will have as much time/money in it as if you put in a Kit. The Kits on this site seem to be well made, noone is making complaints about them. Check the valve guides for wear while it is apart. Worn guides can also add oil to the engines combustion process. Good luck with your tractor project. JimN
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
