Adjusting 460 Diesel Valves
Posted by Smith1000 on August 21, 2006 at 04:36:20 from (64.12.116.65):
Does anyone know if there is an easy way to adjust the valves in a 460 diesel? The head was planed and is back on. The valve clearance is supposed to be .027, set hot. I am not sure what clearance to start out at for the cold setting. I read .002 to .003 in an old posting on this board, but I haven't verified that will work ok. The books says to start on the #1 cyl, compression stroke. Adjust #1 and then rotate the crank 1/3 to the next cyl in the firing order which is #5 (I belive). Adjust 5 and rotate on to the next cyl., etc. To do this, now that I have the vlaves "backed-off", I believe I'll need to pull the each injector for each cylinder to tell when it reaches TDC (wire through hole). Also,I'll have to remove the valve cover when hot. This will be somewhat tricky because of the lack of clearance (fuel tank) and the wiring. I have it on TDC right now, but I am not sure I have it on the compressions stroke. All of the injectors are currently out. The valves rods are loose, but all of the valves have been backed off. The injector pump lines are matched up in the pump window. How does one verify for sure this is TDC-compression stroke. Is there a way to tell by the tension on a different valve? There is a simpler method for some diesels, but I do not know if it will work on the 460. Six of the valves can be adjusted on the compression stroke, #1 cyl. Rotate the flywheel 360 degrees and the other 6 can be adjusted. I don't know if a method like this will work on this tractor. Thanks.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
