Re: IH 2500 ignition wiring
Posted by El Toro on August 14, 2006 at 04:06:00 from (64.12.116.65):
In Reply to: IH 2500 ignition wiring posted by The Beast on August 13, 2006 at 10:48:47:
You should have one wire with voltage that's hot all the time. If your tractor has a starter solenoid, the voltage to your ignition switch is usually fed to this from a small terminal on the solenoid. You need to check your switch with an ohm meter. If your switch is key operated you should have continuity between 2 of the terminals all the time with the switch in the run position. You should have continuity between 2 of the terminals on the switch when you turn the key when you attempt to crank the engine. When you release the key and it returns to the run position you shouldn't have continuity present now. You need to find the hot wire that has voltage. Use your volt meter and set it on dc voltage. Once you find this wire connect it to the No1 terminal. Do not connect any other wires at this time. Using your volt meter again turn the key to run position and check for voltage at the other terminal by holding one the test leads from your meter to No1 terminal and then touch each of the terminals. Should only have voltage on one of those terminals 2 or 3. If you do find voltage present, turn the key to the start position and check for voltage on the other terminal. If you do have voltage here when the key is in the start position and there's no voltage present when you release the key. That's the terminal that feeds voltage to your starter solenoid. You will need to trace the wiring. You should have one wire from the switch to the the tractor's ignition and one to the starter solenoid. Those solenoids usually have the letter s stamped by the small terminal. Hal PS: Is that a new switch?
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
