Re: ATTENTION ALL 300 350 UTILITY OWNERS
Posted by Unreserved dick on August 02, 2006 at 08:39:27 from (4.228.129.247):
In Reply to: ATTENTION ALL 300 350 UTILITY OWNERS posted by Terry Miller on August 02, 2006 at 06:06:33:
This business of plowing with a 300U is a bit complex. The first problem is traction - without wheel weights or tire ballast, only a fraction of the engine's torque is available without spinning the tires. Apparently adding weight to the rear isn't an option for you, so you need to figure on using the smallest plow you can find. A mounted plow tends to add some weight to the rear end, and might be a better bet than a trailer plow, but make sure you pull the pin so the hitch is floating if you go with a mounted plow (see your Operators Manual). A second problem is the type of soil. I think that in an earlier post you said you have heavy clay; this will make plowing much more difficult than in lighter soils, and a smaller plow is indicated. The size of tillage implements you can use is very dependent upon your soil type. Another issue is the 300U's "fixed Fast Hitch" - which doesn't include traction control or any way to adjust the angle of attack (or "suck") of a 2-point plow. If you go with a mounted or semi-mount plow, your best bet is a 3-point rather than a 2-point plow. The 3-point's top link will allow you to adjust the suck angle. Finding wheel weights which fit also may be an adventure; the standard IH weights for the H/M, etc. don't fit. If you are really interested in plowing and other tillage with this tractor, you really need to put more weight on the rear end to aviod an exercise in frustration. Adding ballast to the rear tires might be the most practical idea. For heavy tillage here in Colorado clay, I'll typically have 1200-1500# of weight added to the rear of my 300U to keep the wheel spinning to a minimum. Scratching the dirt with a chisel plow might also be a better short-term alternative to a moldboard plow which you might want to consider. Good luck.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
