Re: Replacing pulley on h water pump
Posted by Haas on June 12, 2006 at 18:21:25 from (12.65.48.88):
In Reply to: Replacing pulley on h water pump posted by RMO/MN on June 12, 2006 at 06:35:43:
I did this a few months back on a Super H. H would be the same. No need to take off the front bolster. You will need to remove the radiator which means removing the steering shaft because it goes through the radiator. The adjustable flange on the H comes off the back side of the assembly, which means you have to take the bearing assembly off to get at it. Since you have do do this, replace the grease seals while you have the opportunity. Also get a ring or two of pump packing to add under the packing nut. You have to remove the water pump driver set up that is in front of the fan, and then the fan and the packing nut and the bearing assembly retainer nut. then you can slide the bearing assembly and the pulley off the water pump body. The back side of the pulley is pressed on and retained by a 1/8 diameter pin through it. I found the pin easy to drive out, but need a press to get the back side off. Lining things up to get the pin back in was not so easy. Had to try it twice. Second time at machine shop. Use a piece of 1/8 rod through the hole in the flange so you can see where to position the flange(scribe some marks) to align the holes when you press it back on. On mine the hole was not perpendicular to anything, so with out something to go buy couldn't get things lined up.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
