Re: PTO won't work on IH 1066
Posted by the tractor vet on June 08, 2006 at 20:23:03 from (64.179.117.134):
In Reply to: PTO won't work on IH 1066 posted by NHBalerman on June 08, 2006 at 20:02:18:
More then likely you sheared the tiny littel pin that hold the valve together . To fix you have to take off the square not on top that the linkages hooks to then drop the plug on the bottom and remove the valve from the bottom and if ya have a two pice valve then the pin is sheared and can be bought at the local Case I H dealer . Now the down side is that the square nut that you took off the top that is how you set the clutch lock up pressure and ya need the special fitting to go into the test port and a gauge that will read 600 lbs. , Now you can buy the fitting for Case I H if the dealer will let you as it is a special test TOOL and sometimes they get funny about ordering it . The gauge you get them from any place that sell a good Hyd. Gauge Now if you can get the fitting you turn the valve stem into the nut with a small nail thru the small hole in the stem till you get around 245-265 lbs. of pressure on the gauge with the hyd . Oil at about 150-180 degrees or operating temp. When i do the set up i have a leg up on ya as i run the tractor hooked to my Flow Rater and warm the Hyd. oil with it and it has a temp gauge on it . Or you can just have the dealer fix it . Also if you have the wick turned up on that 1066 myself i would even run the lock up pressure up to 265-285 that way you will never walk it thru the clutches if you are doing any heavy PTO work. If it is somewhere near stock + 10-15 % then the first pressure set will be fine.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
