Re: Didn't Have to burn the H!!!!!!!!!
Posted by captaink on May 17, 2006 at 17:21:50 from (66.115.214.56):
In Reply to: Didn't Have to burn the H!!!!!!!!! posted by Farmallkid From Ont, on May 17, 2006 at 16:32:29:
Wow a load of questions. First the battery will hold enough charge for several starts, so just because it will start again isn’t a reliable indicator that the generator is charging. Second, ammeters do malfunction, seems to me that when the ammeter goes, so does the circuit but since you have a magneto it will keep running. If you have lights try and see if they work. If you have a known good ammeter replace the defective one. The other option to see if it is charging is to get a voltmeter and take a reading. A 6 volt battery should show 6.5 to 6.7 volts if the generator is charging, 13 to 13.5 or so on 12 volt. Carburetor engines all have their own little quirks on starting and you need to try different choke settings to find which works best for yours. On my M if it above freezing once over on full choke then about half way in will almost fire it up immediately every time (course I’m on 12-volt). The colder the more choke, the warmer the quicker I flick the choke on and off. As far as settings, about one and a half turns out on the main and idle jets is a place to start. Then with it idling, turn the idle mixture screw (should be on the top of the carburetor) in until it runs worse. Then turn it out past the best idle until it starts running worse. Then count the turns as you go back in until it is past the sweet spot and begins to run worse. Now, back it out half the number of turns and you should have the idle set. Now speed up the engine and do the same with the main jet (should be towards the bottom of the carburetor) and you should be very close. You may still need to enrich one or the other if it hesitates on throttle up, or lean out if it smokes black. Good luck.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
