Re: A Charging Problems
Posted by Janicholson on May 15, 2006 at 06:38:00 from (199.17.6.175):
In Reply to: A Charging Problems posted by Doug Wilkins on May 15, 2006 at 06:11:05:
With a fully charged battery on the tractor but not connected to the Neg cable (best to charge it in this case with the Neg battery cable not connected), and all lights and ign off. Using a volt meter, check between the Neg post on the bat and the Neg cables clamp. (hook the Neg black lead to the post, and red to the clamp) If there is a reading more than .5 volts, there is a battery drain. This means the electrical system is leaking energy to system ground. If no volts (good) connect the battery Neg cable and start the tractor. If it charges good, check the voltage across the battery. Black on Neg red on pos. It should be 7 to 7.2 volts. If so it is good. If not that high, thr regulator needs to be adjusted (old automechanics books, and repair manuals needed here). If it does not charge, and tapping the regulator makes it do so, ai wouls replace the regulator. To repair current leaks(as in the second paragraph), remove one wire at a time ,from the electrical connections in the box, and then on the regulator, to see if it stops the voltage flow. If that wire does not change the drain, re-attach it. I hope this gives a starting point for your analysis. JimN
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
