Re: WD9 won't run on diesel
Posted by Ron in Nebr on March 28, 2006 at 14:43:47 from (12.192.38.133):
In Reply to: WD9 won't run on diesel posted by OK PSU Kid on March 28, 2006 at 13:18:28:
Those decompression linkages are notoriously touchy, so yeah, check that first. Since you're getting fuel out the stack(I assume diesel) it's likely you have everything bled out good. If you open the throttle a bit while running on gas then crack the bleeders on the injectors you get good fuel, right? Must be not sealing the cylinders when you switch over from gas. When you pull your valve cover, make sure that when it's on the diesel side there's clearance between the starting valves and the cam that operates them. Also make sure none of the starting valves are hung open. Might not hurt to double check valve clearance on all the valves while you have it off. A quick check to see if anything basic's wrong would be to pull the coil wire and crank it over in the gas mode. Then, while cranking, switch it to diesel. The extra compression should slow down the cranking speed by quite a bit.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
