Re: Super c eng. re-build
Posted by SupC on March 27, 2006 at 19:50:25 from (64.7.225.229):
In Reply to: Super c eng. re-build posted by vally farm on March 27, 2006 at 19:26:03:
Be sure and check the deck of your head, they are bad to leak between the 2 inside cylinders,lot"s of times they are warped up in the center.Also, after you have ran your engine aftyer overhaul, and thermostat has opened and closed, re-torque your head, it"s aggravating, but may save you some leaks later. try to adjust your valves with correct clearance, a couple thousanths can make a good running engine ,run excellent(hope you put in new valves to make a good overhaul).Clean your lower block o-ring grooves real good, and de-burr with emory cloth.I fix a bucket of clean soapy water, and dip the liner in the bucket before installing it, and helpsslide against the oring and into place better.If the top of your block has any dings and nicks, I"d put copper coat on both sides of my head gasket for sure, I usually do anyway.1 more thing, go toCase/I.H. dealer and get a new oil pump gasket for the aluminum plate over the cogs of your oil pump, unless someone has leveled it, this aluminum plate will be warped between the bolt holes, lay some sand paper down on a very smooth steel surface, then lay the mounting side of the aluminum cover on the sandpaper and while holding it down even slide it back forth and level the surface back to flat.Trust me, these gaskets are cigarette paper thin,don"t put more than one,just level the aluminum and you"ll have oil pressure like you"ve never had, I"ve doubled it this way on several tractors. Well, I"ll quit here and let someone else give you there opinions.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
