Farmall Tractors Discussion Board |
A Transmission Seal Job
Posted by Dave on January 10, 2000 at 09:53:38 from (128.113.2.55):
I'm getting ready to fix the seals on my A's transmission/differential assembly. It leaks on both sides. I feel pretty good about it, but I do have a few questions before I start: 1. Why does it leak when it is standing still? This makes me think the oil level must be above the level of the seals, which means the bearings and seals are submerged in oil all the time. I know the trans holds 5 qts, but is it normal to have the seals below the oil level? On the engine, the crankshaft bearings and seals are above the "full" oil level. Is the trans. different? Can I check the oil level without draining it all out to see I have 5 qts? 2. I hear there are both felt and rubber seals available. I have read that the felt ones are too thin, so that two must be sandwiched together for the proper thickness. It makes sense to me to slide the seal over the end of the differential shaft, and then slide the shaft into the differential to avoid pushing the seal into the case. Does this make sense? Also, Central tractor sells what it calls "Rear Axel Seals" for a 'A,' but I would say they are for the rear axel: down where the wheel goes, and not the differential. Is this the right part? Or should I go to NAPA? What kind of specs. does NAPA need to get me the right seal? I guess shaft diameter, but do they need thickness or other info as well? I see I went on a bit, but thanks for reading through all that. I appreciate any experience/advice you can share.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
