Re: SW 6 miss or problem
Posted by Janicholson on March 02, 2006 at 06:48:11 from (199.17.6.175):
In Reply to: SW 6 miss or problem posted by joel shelton on March 01, 2006 at 19:03:48:
The ideas below are very good first efforts. If things seem to be the same, pull the dist cap and rotor, grab the dist shaft and move it in all directions (except in and out) if you can detect movement (play in the bearings, it needs to be rebuilt. It is common (recient thread on here ) for the shaft box to be ignored for life, then the shaft life ends. Longer bushings contacting the shaft in new unworn areas can fix even a worn system. Same exact symptoms as described. It causes radicall dwell changes and timing irregularity as the advance mechanism rotates the dist cam. Good hunting,
JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
