Re: CALLIN ALL FARMALL H EXPERTS
Posted by Wayne Swenson on February 13, 2006 at 08:43:45 from (66.228.250.33):
In Reply to: CALLIN ALL FARMALL H EXPERTS posted by 1945farmallH on February 13, 2006 at 06:07:08:
First, make sure the timing is set correctly. Late timing (too small of a gap or incorrect setting) will act like too rich carburetor problems. Timing should be set so the points open (set the gap first, .016" for battery ignition) when the timing pointer is between the double marks on the pulley; use the crank or turn the fan by hand (switch off) to locate the marks. With the switch off; use an ohmmeter or self powered test light to verify the point opening instant. This can be done with either #1 or #4 at TDC. Loosen the 2 distributor hold-down cap screws and rotate the body of the distributor in the direction of normal rotor travel until the points are closed (test light is on, ohmmeter reads very low ohms). Now rotate the distributor body backwards until the points JUST open; lock the cap screws and you are good to go. It is CRITICAL for the points have to be CLEAN and ADJUSTED first. If you have a 12 volt test light, turn on the switch after locating TDC and follow the same proceedure. The light is on with points closed and off when the points open. Needless to say, points, rotor, cap, & wires have to be in decent shape. Now start the engine & warm it up in NEUTRAL and BRAKES LOCKED; run at WOT (wide open throttle) and turn the high-speed adjusting screw in & out to find the "sweet spot" where the engine runs its fastest & smoothest. Turn this high-speed screw out an extra 1/2--3/4 turn for power. Idle the engine down & set the idle speed. Now turn the idle mixture screw in to richen, out to lean so the idle is smoothest.(this is an AIR adjusting screw so works opposite of the main fuel screw on the bottom of the carb) Re-adjust the idle speed. Perform the carb adjusting procedure another time to be sure all mixtures are correct. Don"t forget that in the winter your air cleaner may cause richness due to cold oil in the cup or even ice blocking the air passage.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
