Re: 706 gasser rebuild
Posted by the tractor vet on January 03, 2006 at 20:03:02 from (4.124.73.181):
In Reply to: 706 gasser rebuild posted by nickWI on January 03, 2006 at 17:38:09:
One thing that most people overlook on the C seires engine is the bore classifcation on the top of the block buy the cylinders you will see A-B C-D now when you get a rebuild kit from aftermarket they only come in A-B class and if you have any holes that are in the C-D class then the new sleeves will be loose in the bore and stand a 99% chance of snaping the flang off and pulling the sleeve down around the crank. Now the next thing is the deck of the block it needs to be checked for strightness and if needed milled down to true up when this is done then ya have to recut the counter bore and set sleeve hight and here again it will be off 95% of the time . Also the head will need resurfaced . Also have both ends of the rods redone . Now what you can do is make that old 263 into a 291 with the upgrade sleeves and this will make all bores the same but this requires boring the block and that is not a big deal and it realy spices up and old 706 gasser. Now if you do this you will have to cut the timming back to nomore then 20 degrees at full throttel as you have now uped the comp and the timeing is a big deal on the 6 cylinder and also the use of 93 octain gas also when fitting the pistons each one MUST BE MIC. AND A CLEARANCE OF .004 skirt to wall clearance MUST BE MAINTAINED each piston is differant and fitted to the hole that you put it in.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
