Re: Trouble Starting (49-M)
Posted by John T on November 22, 2005 at 10:55:01 from (66.244.90.98):
In Reply to: Trouble Starting (49-M) posted by fisherman on November 22, 2005 at 07:04:57:
Fisher, the very first thing I would do is remove, clean n wire brush, then reattach each n every battery n starter n ground cable n have the battery well charged n see what happens. If no help, have the battery load tested or try a know good substitute battery. Its possible for old cables to look good outside, but theres been arcing and the resultant carbon which can mess them up even where not visible. Another critical factor is the ground quality. The ground should be attached to a good clean (remove n wire brush n get a new bolt etc) frame type bolt as opposed to a thin or rusty sheet metal component. The closer to the starter the better. On 6 volt systems I HIGHLY RECOMMEND the use of 00 or at least 0 Gauge cables. On 12 volt its still the bigger the better, but you can get by with 0 or even 1 or 2 Gauge BUT I WOULD NEVER USE LESS MYSELF. Whats you need to reduce is voltage drop across resistive cables such that the stored battery energy gets expended in the starter where its needed versus wastign it as heat energy across too small cables. Soooooooo once you have good cables,,,,,,,,a good battery,,,,,,,,,,,,a good ground,,,,,,,see how she cranks. If when cranking the battery voltage drops drastically and/or the lights dim way badly, its possibe the starter is bad or maybe its mechanically stuck/jammed??? If thats the case, an engine rocking or loosening the starter may free it. HOWEVER if the battery voltage dont drop or lights dont dim much I would suspect a faulty starter switch or the starter contact. As far as voltage,,,,,,is the charging system keeping the battery up or you need to charge it now n then???????? Is there a working ammeter and does it swing to - discharge if you turn on lights or ignition not running but swing to + charge when running??????? If so shes charging at 12 volts okay. If its charging, the battery voltage ought to read 12.6 volts sitting but rise to 13 and over at wide open and/or the lights glow noticeably brighter, does it do that?????? If so, again, shes charging at 12 okay. Is it a genny or an alternator??? as most all alternators are 12 volts and negative ground. If it were changed from 6 to 12 volts, the coil would need to be changed to a full 12 volt rated coil or else add a series voltage dropping (12 to 6) ballast resistor, otherwise, the coil will run hot and the points burn up prematurely. Whats your coil?????? Have any external Ballast Resistor??????? If changed from pos to neg ground, the coil leads should be swapped so + is from switch and - to distributor, is yours????? Sorry so many questions, but we gotta know this stuff to help you. Post back your findigns n answers n let us all know what happens. Good luck n God Bless John T
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
