Re: 6 volt battery hookup
Posted by John T on November 16, 2005 at 10:56:33 from (66.244.90.98):
In Reply to: 6 volt battery hookup posted by brian 37 on November 16, 2005 at 08:18:06:
Brian, I pretty much agree with the captains good advice. The starter will still turn the same direction n work REGARDLESS if it were hooked Positive OR Negative ground. I think the first thing I would do is remove, clean n wire brush, then re attach that smoking connection cuz it may be loose or burned or corroded. To be safe, you may as well remove, clean n wire brush, then reattach each n every battery n starter n ground cable (and where the ground cable attaches to the tractor frame) while youre at it. Im thinkin its EITHER a bad connection or the starter itslef may be bad or else its mechanically stuck/jammed. Once you fix the loose connection, see if when you try n crank her the lights would dim badly or the batterys voltage drops drastically, in which case I suspect a bad or a stuck/jammed starter. Loosen it n retighten and/or crank the engine somehow to see if it will free up??? Mabe the starter drives jammed into the flywheel teeth?? If when trying to crank theres no smoke or sizzle and the battery voltage dont drop much and/or lights dont dim much, then I suspect the starter switch may be bad or the starter where it connects to the switch. You may wanna also check where the ground cable attaches to the tractor for a loose or burned connection and any connection on the switch n starter??? John T
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
