Re: International 340 backfired and died
Posted by Janicholson on October 29, 2005 at 08:31:29 from (66.173.50.22):
In Reply to: Re: International 340 backfired and died posted by farmall 340 on October 29, 2005 at 08:11:58:
Diagnosis is the main event. 1}it is getting fuel (or no Backfire) 2)it is getting spark (or no Backfire) 3) The timing is off or it would run fine Two types of timing, ignition timing and valve timing. Both are direct causes of Backfire problems. If ignition problem (simple) the points self destructed, ot the rotor/cap got water in them and is crossfiring (why did chrysler name a car for bad ignition). Or the cap got bashed by a branch and moved far enough to break the rotor drive spline on the dist shaft. If ignition problem (complex) the drive gearing to the distributor has come to grief. somewhere between the hyd pump, and the breaker cam. There are usually gears and bearings, and centrifugal advance springs and stuff in there that might be broken. The Ignition timing is also directly controlled by the valve timing gears from the crank to the hyd pump drive. If this system goes out, or slips it is either bad , or very bad. If bad it is just a keywak or drive hub or pump shaft drive giving wrong rotational relationships to thje dist. If it is very bad, it is the valve timing mechanism and that requires removing the fromt cover and getting much dirtier. Good luck and I hope it is a broken rotor. JimN
Home
| Forums
Today's Featured Article -
Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
