Re: Farmall M steering play
Posted by Slappy on September 02, 2005 at 10:02:36 from (143.88.85.82):
In Reply to: Farmall M steering play posted by Beginning Farmer on September 02, 2005 at 08:06:29:
This is a common problem, and you can access a lot of info from the archives. The place to start is by having the parts catalog handy - the exploded view is invaluable. Binder Books has reproductions if you need to order one. 3/4 of a turn is a lot of play and you may have to repair or renew several parts to get really good results. I would start with the obvious and easy things. - make sure that the woodruff key between the front steering shaft and the universal joint is good. - tighten the large nut at the top of the upper bolster located in the worm and sector gear oil pot. Look for broken or missing teeth while you are there. If the gear is shot, you may will need a "new" sector from the bone yard. -tighten the second large nut on the end of the front steering shaft. Get to it by removing the cap on the front of the worm and sector oil pot. Check the bearing held in by the nut - if it's bad replace it. - check the front wheels for play and make sure the bearings are good. This would be a good time to repack them too. These fixes are relatively easy (you just have to remove the tin and a few bolts) and not terribly expensive. If you still have play you will need to replace one or more of the following: upper steering bushing, lower steering bushing, steering thrust bearing, and/or the thrust bearing spacer. These repairs will require removal of the front wheels, droping the bolster and pressing or driving out bushings and seals - not always hard, but always heavy and a little pricey. Good luck!
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
