Re: SUPER C STARTER PROBLEM - NEED HELP.
Posted by John T on August 29, 2005 at 15:12:18 from (66.244.90.98):
In Reply to: SUPER C STARTER PROBLEM - NEED HELP. posted by farmallhal on August 29, 2005 at 07:49:52:
Hal, Im not all that familiar with Farmalls, more experienced in Mother Deeres, but have found the problem often is EITHER the copper looking button/post on the starter OR the washer/contactor in the switch is pitted/burned/carboned up. If the starter post is all burned n pitted I have gotten temporary relief by cleaning n wire brushing n light filing it down smooth (If its burned/pitted too deep, it needs replaced) HOWEWVER, if the contactor/washer on the switch is burned or pitted or carboned up badly, it needs replaced. Also, if theres any mechanical restrictions or limitations in the rod n linkage that prevents depressing the switch fully, that can cause arcing n carbon build up in the switch. I dont have much luck by jumping direct with a big battery cable to the starter post, cuz it tends to arc badly and its hard to keep a good electrical connection. Also the real test is if the starters under a load as that direct jumnp test dont tell you as much if the starter is able to free spin unloaded. Its possible for a starter to become mechanically stuck/jammed with its drive gear into the flywheel teeth, so check that out first by loosening n rockign before you try any starter jump tests. A bench test can tell you some as the starter should torque kick pretty hard upon start and spin pretty fast and if not, shes obviously BAD, but thats not under a load so its no guarantee its still good just cuz she runs good not loaded. If the starters not too bad, I have had luck simply by taking it apart and cleaning things up and polishing down and removing any film from the commutator. Good luck n God Bless John T in Indiana, retired electrical engineer
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
