Re: 1466 hydraulic question
Posted by Aces on August 26, 2005 at 13:51:24 from (4.164.51.202):
In Reply to: 1466 hydraulic question posted by gary fedyn on August 26, 2005 at 12:48:16:
Gary. The first thing to do is to put some weight on the 3 PT Hitch lift it up, shut off the tractor and leave it set over night. If the hitch is clear down in the morning, you have a leak inside in the hitch system in the rear end some place. If it does not go clear down it would be an adjustment. After you shut off the tractor with weight on the hitch you can check for leaks, first you can remove a plate below the seat right behind your feet as you set on the seat. A 1-3/4" by about 3" plate with I thing 4 1/4" kex head scp screws, take it off no oil should come out, you should see a valve stiking out the left side of the hitch cylinder, about an inch hex. This is the cousion relief valve if oil is dripping from the end of the valve that is a cause for what you say is happening. Don"t put you finger over the end of the valve to see if it is leaking, just look to see drops of oil. The control valve is on the right of the cylinder should be able to see just the top look for oil leak an other cause. If the hitch goes down, and you don"t see leak at the first 2 places then you will have to put wieght on the lift arms and not use the third link so you can look in the back through the third link hole to look for oil leaks from the cylinder piston. again no oil should come out and no fingers to check for leaks it only takes 700 PSI to penetrate the skin and you have more than that if you have much of a load on the hitch. When you look for leaks through the third link hole they should be from cloose to the cylinder. This looking just gives you a good idea where it is coming from, you will have to remove the rear deck to fix. If the hitch goes down over night you do have a leak, the pump has nothing to do with this.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
