All of the above is good advice. Another possibility is points never opening inside distributor (adjusting screw came loose, perhaps) or a short to ground (failed condenser, or condenser wire shorting to case). I would first to do the spark test, and expect a fail. Then I'd use light or VOM to check coil wire at coil and key switch (with points open). If you do the hot wire jump to coil, be sure to pull the existing one as we suspect a short to ground. If that fails, and voltage is good to the coil, , then I'd test voltage along the way from from coil to moving point. Also make sure voltage disappears when points are closed. That done, you begin to suspect the coil itself.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
