Re: F12/F14 Timing/fail to start
Posted by Pete in Holland, MI on July 12, 2005 at 21:46:13 from (24.231.248.86):
In Reply to: F12/F14 Timing/fail to start posted by DA@STL on July 12, 2005 at 18:47:36:
Several good comments thus far. Need to separate if it is a gas or spark problem. Gas - Squirt some gas down the carb or a few teaspoons directly in a couple cylinders & crank. Coughs & sputters, then quits, tis a gas problem. Electrical - If after the test above, nothing happens, spark or timing may be the problem. Pull all the plugs. Crank engine slowly till #1 cylinder is coming up on compression (thumb over hole pressure test). With mag fully retarded, inspect piston thru hole and verify mag trips at TDC. Rotate the engine 2 full revolutions again but stop just short of TDC. Remove the distributor cap and note that the contact on the fiber gear is around the 1:30 -2:00 position, and that the wire from the upper right of the distributor heads to the #1 cylinder. This exercise verifys timing and proper wire to the cylinder. My F-12 starts on the first or 2nd quarter turn most every time. Don't need the choke unless starting in the winter. Good luck. Let us know what you found.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
