Re: Fuel lines and tap settings International 484
Posted by JB2 on April 20, 2005 at 19:22:11 from (24.157.143.220):
In Reply to: Fuel lines and tap settings International 484 posted by Greg Barron on April 20, 2005 at 17:43:20:
Hi Greg, my brother has a 454, 495 and 684. The 454 and 495 are the same as 484. The 684 has larger motor, T/A and Cat II 3pt hitch but everything else is the same. To answer your fuel tank/line question: The fuel tank is like an upside down U or saddle tanks as they are sometimes called. The purpose of the line between the sides at the bottom is to equalize the fuel level in both sides of the tank as the only time the fuel will flow between the tanks is when it is filled above the level of the top of the U. The line that goes forward from the bottom right (looking from rear) is the fuel feed line that goes to the input of the primary fuel filter. Depending on the year your 484 was made you may have two small CAV type fuel filters on the front right of the engine or one large fuel filter with a drian tap on the front left of the engine. The line that goes from the bottom left of the tank forward is the fuel return line from the top of the injectors. This returns unused fuel from the injectors back to the fuel tank. Re shutoff valves, I believe they are screwed counter clockwise to shut off the fuel flow. This means the there is more of the shaft of the T shown when they are shut off. Here is what happened to my brother's 684: Every so often it would loose power on a hill or sometimes the engine would die, if you let it sit for 5 minutes away it would go again till next time. So finally last fall he took the line off at the bottom right tank and proceeded to drain the tank. He only got about 1/2 the amount of fuel out of the tank he expected and the fuel guage (only measures in left tank) was still showing the same. He then took the line off the bottom left and there was no fuel flow, took the shut off valve out of the bottom left tank and the rest of the fuel came out. There was a carcus of a lady bug partially plugging the shut off valve in the left tank so when the fuel level would get below the level of the U only the right side of the tank was suppling fuel and occassionly the right side would run dry and starve the engine. Eventually enough fuel would flow thru the partially clogged valve to start the engine again. Hope this helps JB2
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
