Re: Farmall Timing, distributor problems
Posted by P Backus on March 26, 2005 at 08:35:11 from (66.181.141.7):
In Reply to: Farmall Timing, distributor problems posted by Chris Willy on March 25, 2005 at 22:47:19:
Chris, what I would do is to get #1 piston on TDC on the compression stroke (#1 is closest to the fan). Make a mark on the side of the distributor where one of the spark plug towers is on the dist. cap. It really doesn't matter which one, just pick one. That will be your #1 plug wire. Remove the distributor at the 90 degree connection. That will diconnect the distributor shaft gear from the gear on the shaft going to the hyd pump. Now reinstall the dist. with the rotor on so that the rotor is pointing directly at the mark you made on the side. You may have to do it a couple of times because the dist. shaft will turn a bit as you engage the gears. Do you have a hand crank for your M? It would work well to turn the engine maybe 1/2 turn and then see which way the distributor rotor turned. Then all you have to do is connect your spark plug wires accordingly. Firing order is 1-3-4-2. Time the engine as you normally would. Let me know if this isn't clear and I'll try to 'splain it better! Paul
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
