Re: Mccormick IHC AOS6 questions
Posted by Novel Idea Guy on January 28, 2005 at 05:36:42 from (64.80.110.40):
In Reply to: Mccormick IHC AOS6 questions posted by Anthony Gillam on January 27, 2005 at 22:19:34:
Sounds like you've got PEBSAS, problem exists between seat and steering-wheel. If the previous owner could start it, you can to. You just have to do what he did, follow the same procedure. First off, if that "Airostart" stuff is starting fluid, ether, THROW IT AWAY! You're gonna blow the engine up. You don't need ether to start an engine on petrol/gasoline/crocodile juice/whatever you Aussies call it :) You tore the carburetor apart. Why? The tractor ran fine when you bought it. It's highly unlike the carburetor wore out or got that dirty between then and now. Do you know how to work on a carburetor? Its flooding now, so that means you put it back together wrong. The float is set wrong, and isn't closing the flow of fuel off when the carburetor bowl gets full. If the distributor cap is broken, replace it. Come now, that's just common sense... But, if it ran with the broken cap before, and you didn't break it further, it should run with the broken cap now. What do you mean, "can't find neutral?" There is no specific notch for neutral. Neutral is just "not in a specific gear." If you knew that, then the shifter rails could be worn and the tractor could be stuck in a gear. AOS6 is probably similar to the OS6 in the USA, which is basically a W6, which is basically an M. You'll probably want to pull the shift lever off and make sure all the rails are aligned for neutral. If it still won't roll with the clutch out, then you've got more serious issues. Above all, don't start tearing into things without doing your homework first.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
