Re: It almost started, my 44 H Cont.
Posted by riverbend on January 09, 2005 at 20:44:00 from (208.160.33.141):
In Reply to: Re: It almost started, my 44 H Cont. posted by tanner clark on January 09, 2005 at 14:02:10:
Fuel dripping out of the carb after you choke it is pretty normal. I would not run the tractor with the air cleaner disconnected. There is a weep hole in the bottom of the carb to let the excess fuel out. Take MagMan's advice to heart. Don't over think this. Farmer Bob told you the layout of the valves. When both valves on #1 are closed and the pointer is lined up with the first double notch, The #1 cylinder is ready to fire. The points need to open to create the spark and the rotor has to send it to the right plug wire to get it to #1 cylinder. The motor does not care where the distributor rotor is pointing as long as it is in time with the cylinder that is ready to fire. The 2 'o' clock position mostly has to do with the number "1" molded into the original distributor cap. In any case, you will need to get the motor, the points and the rotor all in time to get it to run. Back to MagMan's point - just do the minimum to get it running. It sounds like you need to fine tune the timing to get it to start. Get #1 to TDC on compression and follow the instructions in paragraph 179 of your IT manual- Loosen the distributor clamps and turn the distributor body clockwise about 1/6 of a turn. Hold the distributor end of the coil wire 1/8" away from the metal distributor body. Turn on the ignition and slowly turn the distributor body CCW. When you see a spark, stop and tighten the distributor clamps. Shut the ignition off. Make sure your plug wires are in the right order. Give it two cranks of full choke. Open the choke, advance the throttle about a half a dozen clicks, turn on the ignition, and it should start.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
