Re: Hitachi alternator wiring instructions needed
Posted by F-Dean on December 10, 2004 at 19:18:50 from (12.74.46.2):
In Reply to: Hitachi alternator wiring instructions needed posted by llerrit on December 10, 2004 at 09:40:26:
I just finished putting a Hatchi Alternator on my M using guidance from BIG JOHN and Bob Melville. BIG JOHN has been putting a Hitachi #14231 alternator on several tractors in place of a generator under the hood. This alternator was used on 1978-79 Nissan 620 pickup with a 2 liter engine and a 1980 Nissan 720 pickup with a 2 liter engine. At NAPA it is part #2138130. The cost of a rebuilt alternator is approximately $50 + core (And they won’t take a generator as a core). The alternator is 4 1/2" in diameter and 7" in length and will go right on the original mountings on the tractor. Use an 8" x 3/8" bolt and some pipe for spacers. Being Hitachi means that it is METRIC. You will need to drill out the mountings to 3/8". The tension adjusting bolt is also metric thread. The alternator is a three (3) wire set up which can be converted to one (1) wire. There are spade connections labeled S & L and a BAT post connection. The L spade is for the idiot light and can be disregarded. Use a jumper wire from the S spade to the BAT post and you are good to go. The pulley is a split type that you can widen using a spacer (once again metric). You will need to use a disc type lock washer and some “Locktite” because there won't be room to reuse the split lock washer that comes with it. I put the washer between to parts of the pulley to make it fit the existing belt. There is a built in regulator and a resister to keep the battery from feeding back to the alternator. According to BIG JOHN, This is a sweet fit under the hood that he has used on H's, M's and W models, also Cubs and many others. I add the following from my experience: Be sure to switch the polarity of the battery to Negative ground to avoid damaging the Alternator. Consequently, you need to switch the wires on the coil, if you are using a coil. Use a step-down resistor to the coil to keep it at 6 volts if you are using a coil. Use a plastic covered connection when you connect the jumper wire from the S spade On a Farmall M, turning the bracket upside-down will allow the alternator to fit nicely inside the hood using the existing generator belt.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
