Re: Allan in NE-carb photo
Posted by Ron in Nebr on November 25, 2004 at 08:57:30 from (65.169.97.23):
In Reply to: Re: Allan in NE-carb photo posted by Allan in NE on November 25, 2004 at 05:11:03:
Hi Allan, happy Turkey Day! From looking at both his carb pics, it appears to me that the actuating rod for the pump is indeed in place. Most likely, as you mentioned, it needs a new pump plunger. There's usually some adjustments to be made on these pumps. I always had the best luck with the actuating rod in the top hole(nearest the pivot point) on the "rocker" assembly. This'll give it the fastest response. A very critical measurement on these is how far the pump plunger itself sticks up above the main body of the carb. The pump plunger is what the little "S" shaped link is hooked to on the rear of the pump pivot "rocker" assembly. If the plunger is too high, it will uncover a slot in the main pump well that's used to feed fuel to the pump, and it won't give any pump shot until it moves low enough to cover this slot back up. There should be a measurement for this in the original instructions that came with the carb. If not, there'll be one in the carb kit that you have to buy to get the new plunger. A quick check he can perform is, with the engine OFF, looking down the primaries, move the throttle shaft slightly. There should IMMEDIATELY, with even the slightest throttle movement, be two good streams of fuel shooting out, one above each primary throttle venturi. If you can move the throttle and there isn't fuel squirting out in the venturis, OR it takes several degrees of throttle movement before the fuel starts to squirt, OR the fuel just kinda trickles out and doesnt come out in two good streams, it will result in the symptoms described. As a side note, and maybe I'm thinking of something else here, on the AFB's I've been around, at least the "Competition Series 750 AFB" that I had, there was an air valve plate above the secondarys. This was controlled by a counterbalance weight. This would only open when the engine airflow demands overcame the counterbalance weight. You could "tune" on it by grinding some off the weight, or adding weight to slow it down. Anyway, I don't see any such air valve plate above the secondarys in these pics. Maybe the 600 AFB's didn't have them? But if it's supposed to be there, and for whatever reason it's gone now, it'll sure cause those same symptoms as the secondarys open up before the engine is ready for them.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
