Re: 504 STUCK IN GEAR
Posted by K.B.-826 on October 25, 2004 at 18:35:44 from (209.163.30.30):
In Reply to: 504 STUCK IN GEAR posted by Christopher on October 25, 2004 at 17:09:47:
This is a very common problem with an easy fix. The end of your gearshift lever is worn to the point where it can slip out of the shift fork it is moving before the fork gets back to nuetral. Remove the shift lever. Look down in there, and you'll see the three shift forks. They each have a notch cut into them where the shift lever engages them. When the tractor is in neutral, all three of these notches should be centered with eachother. You will have one that is not, use a large screwdriver or prybar to line it up with the other two. Weld up the end of your shift lever and grind it back down to a size and shape that fits the notches in the shift forks nice. If you just put the shift lever back on there the way it is and keep running the tractor, there's a very good chance you'll get into two gears at once, pop the clutch, and then you'll need a complete transmission rebuild. Now would be a good time to check your TA linkage adjustments. If your TA clutch is not disengaging when the main clutch pedal is depressed, it will make the transimission harder to get out of gear, and that increased effort will only make the shift lever more likely to slip out of the fork.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
