Re: Farmall b crank seal
Posted by Jim Becker on September 15, 2004 at 19:21:41 from (4.29.47.118):
In Reply to: Farmall b crank seal posted by William Moore on September 15, 2004 at 12:09:22:
The hard part is pulling the pulley off. Early pulleys have a setscrew but later ones are just pressed on. In either case, you need a good, heavy puller. You need to use a big bearing splitter behind ther pulley of you will braek a chunk of the flange off. There is a threaded hole in the end of the crankshaft. Run a bolt into the bottom of that hole so you can push without damaging the threads. You use a threaded rod in the crankshaft hole with a nut to pull the pulley back on. It goes easier if you heat the pulley in an oven before installing it. While the pulley is off, you pull the front cover, replace the seal then reinstall the cover but leave it loose until the pulley is back on. After the pulley is back on, let the seal center itself on the pulley then tighten the cover.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
