Re: Re: Re: Re: Re: Re: Engine knock F-20
Posted by George Mikesell on September 07, 2004 at 13:34:17 from (209.42.79.239):
In Reply to: Re: Re: Re: Re: Re: Engine knock F-20 posted by TMAC on October 25, 1999 at 19:39:24:
I have been studying what you have said about the knock on the f-20. First of all the back and forth movement of rod on crank is normal, it is built in. You need to make sure of crant to rod bearing clearance. This would be vertical movement. You really need to check this clearance at top of stroke and then half way down or when the through you are working on is horizontal. This for checking flatness of crank. Or better yet would be to mike the shaft. Yes this can be done fron inspection hole. That was the idea of inspection hole, you can remove the piston and put in rings this way, not easy but can be done. If the rod is truly loose I would want to know why it did not get oil. Pan is not hard to remove I would pull it and see if the oil line is pointing at the dipper. Or if it has came loose and not oiling the rod at all. Also the dipper may be messed up or have something in it thus keeping rod from being oiled. My best advice at this point is check evgerything from oil pump to oil distribution and dipper. Ps clean oil pan and run water through the main tube check for leaks and where waater shoots out will give you good idea if oiler is pointed ad dipper. You can adjust rod bearing by taking out shims, three and one half thousands to five is good fit. Use plasti guage to check can be gotten at local parts store. Remember Check and find out why the problem has occurred.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
