Re: Cub 184 very frustrated
Posted by lee on July 25, 2004 at 19:37:53 from (24.24.95.246):
In Reply to: Cub 184 very frustrated posted by Dieselrider on July 25, 2004 at 14:12:49:
Yes, I would agree the unit should be torn down, cleaned, inspected and repaired as required. The long rock shaft that comes out of the gov housing is supported by a needle bearing on the side where it exits the housing, a blind hole on the far side of the housing internal and also runs thru a third bracket on the left side of the tractor where the throttle rod hooks up. There is plenty of opportunity for this shaft to bind if bent slightly or worn bearings or the bracket out of alignment. The needle bearing may be worn into the shaft causing a bind or it can bind where it runs thru the external bracket. There is another lever on a pivot pin that couples the throtttle lever thru a spring to the rock shaft. This lever must be free to move and the spring of a specific length and spring rate. Not just any spring works there. Internal there are several other moving parts: fly weights held on a shaft by pins and a thrust bearing to impart motion to the rock shaft. There is also a second spring. These can also give trouble if excessively worn or perhaps broken. If you have not been able to adjust it there is obviously something wrong with it. But it is a simple device and can be repaired. I would not cut corners in repairing it as the governor is a key element in the proper working of the tractor. Your effort will be well spent.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
