Re: super c fast hitch
Posted by Stan(VA). on June 13, 2004 at 20:18:55 from (208.59.157.77):
In Reply to: super c fast hitch posted by Gary Cole on June 13, 2004 at 14:01:44:
Yes, it's just one more of the several companies making hydraulic parts. You need an open center (as opposed to closed), two-way (as opposed to one-way) valve to control your hitch. If it's a single spool valve, it should have 2 work ports (usually 1/2" NPT) that go to the cylinder, and an inlet and outlet (usually 3/4" NPT) for your pressure and return lines. Basically any valve should have the inlet and outlet ports, then 2 work ports for each spool. If the seller doesn't know for sure, try to look up the model number online. It'll take someone smarter than me to tell you how to ID it by sight; as far as I can tell, valves use the same outer casting but can be configured multiple ways with internal parts and port blocks.
It should be two-way like I mentioned (two hoses). I think the original cyl was 2 1/2 x 8. I've used generic 3" x 8" cylinders, and even used a 3 x 10 for a little more range on one tractor that worked great; but be carefull with that one as it's possible to break off the upper connection on the cyl when the hitch is angled and you lift it all the way up. Don't ask how I know that ;)
Stan(VA).
Post a Followup
: Re: Re: super c fast hitch
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
