Re: Super C front main seal/pulley removal
Posted by BIG JOHN on May 23, 2004 at 17:03:35 from (64.12.117.22):
In Reply to: Super C front main seal/pulley removal posted by Jamie Reinsborough on May 22, 2004 at 19:54:33:
Here is a step by step set of directions. First remove the hood and grill. Next pull the raditor. Now rmove the fan, belt, generator. Remove the lower water outlet housing. Now you will need to rig up good blocking to hold the tractor with the front end off the ground, Next disconnect the steering rods from the chasis, now you are ready to unbolt the front bolster and move it off to the left side. Next disconnect the govener and remove the housing. NOW you are ready to remove the pully. Make sure that you have a "Split Bearing Puller", place it behind the pully and attach a two jaw puller to it. The pully is a press fit so start with just the puller but in most cases you will have to use and Act Torch to heat the coller in order to get it off. Now with the pully off you can remove the timing gear cover and replace the seal. The seal comes out the back. While you are here you should clean and inspect the govener making sure it moves smoothly and that the thrust bearing is in good shape. Make sure that you get all of the timing marks in the right place when you put it back together. Now just reverse the process. Sorry if this sounds to involved but it is the only it can be done. GOOD LUCK
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
