Re: 300U T/A.
Posted by Red Rider on May 14, 2004 at 21:00:43 from (66.235.45.149):
In Reply to: 300U T/A. posted by Loren on May 13, 2004 at 23:25:19:
Ok Loren let me brefely explain how the TA works. When the TA lever is forward you are in direct drive. When the lever is back your in the low range side. There are two clutches, the main clutch and the TA clutch. When in direct (TA lever forward) the TA clutch is engaged and the whole planatery TA unit rotates turning the input shaft into the transmission. When you pull the lever back you disengage the TA clutch and the rotating power goes through the planatery reduction gear set giving you the lower gearing to the transmission input shaft. So If the TA overrun clutch system was shot your tractor would just plain stop when you pulled the ta lever back. The fact that nothing happens when you pull the lever back tells me that the TA clutch is not releasing for one reason or another. It could be the linkage is out of adjustment. My 400 diesel did that once and it turned out to be one of the bolts that attach the TA pressure plate to the TA flywheel. There is an inspection plate over the TA that you can take off and make sure all the pressure plate bolts are tight. Get you a manuel and adjust the TA exactly as instructed. Let me know what you find.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
