Re: Re: Re: Converting to 12 Volts
Posted by Bob on April 15, 2004 at 20:36:57 from (66.163.134.177):
In Reply to: Re: Re: Converting to 12 Volts posted by Scotty on April 15, 2004 at 19:22:37:
Scotty, Apparently you have tried a couple of resistors on your tractor? The way a resistor works, it has to be powering a load (Current flowing through it) to show a voltage drop across the resistor. You must have checked the voltage on both sides of the resistor with the breaker points open, so there was no current flowing in the ignition circuit. That is why you got the 12 Volts in and out. If you still have one of the resistors, try it again, and start the engine, and use an analog voltmeter to check the voltage on the switch side of the coil for the 5-7 Volt range I posted before. If you are within that range, you SHOULD be OK. The reason for using the analog voltmeter is that a lot of digital meters will be affected by the EMF produced by the ignition and charging system, and may go "nuts" and read incorrectly. An analog meter is less sensitive to the electrical "noise".
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
