560 hydraulic problem
Posted by joe on March 27, 2004 at 18:08:53 from (205.146.39.83):
The hydraulic system is making a squealing sound and keeps the engine under load. If I put a short jumper hose between two remote outlets and hold the lever back for that outlet, it unloads the engine and most of the squealing subsides. The power steering works fine except the wheels shimmy just a little (tractor stopped). I changed fluid, changed the filter which needed serviced, and the teledepth control had some teeth broken off the differential gears. I disconnected its linkage to the hitch and can move the spool valve in and out with the side lever which makes the noise worse. Any help on how to solve this problem, what to check or do next would be appreciated.
Post a Followup
: Re: 560 hydraulic problem
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
